Artur2505
Nov 03, 2024Tutor
RBE971 iphone is keep disconnecting and room 15ft away no connection
I don't know what's going on but I had orbi 6e mash and never had any problems before Room next to other room where is router connected, my phone is not working with wifi Usually few times a day ran...
KevinLiT
Nov 12, 2024NETGEAR Moderator
Hello Artur2505,
Welcome to the NETGEAR Community!
I understand that you are having intermittent network disconnects on your RBE971 with firmware v9.12.3.3.
Please download and install the most recent firmware version 9.12.4.16 to resolve this issue.
Please navigate to the link below to download firmware version 9.12.4.16:
https://kb.netgear.com/000066418/RBE970-RBE971-Firmware-Version-9-12-4-16
Best,
Kevin
Community Team
Best,
Kevin
Community Team
Artur2505
Nov 13, 2024Tutor
I do not understand my firmware update on my router is up to date.When I'm checking on Orbi app no new firmware available
Do I need to manually download and install?
If yes should it be done thru website?
Admin login?
Admin login?
- FURRYe38Nov 13, 2024Guru - Experienced User
NG may not have it up on there AU services. So you'll need to manually install the FW. RBS first, RBR lastly thru there web pages. I found this process works best: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2359585/highlight/true#M53030
Also if your in the EU region, do not attempt to load this version of FW.
Admin login?
