Artur2505
Nov 03, 2024Tutor
RBE971 iphone is keep disconnecting and room 15ft away no connection
I don't know what's going on but I had orbi 6e mash and never had any problems before Room next to other room where is router connected, my phone is not working with wifi Usually few times a day ran...
Artur2505
Nov 13, 2024Tutor
I do not understand my firmware update on my router is up to date.When I'm checking on Orbi app no new firmware available
Do I need to manually download and install?
If yes should it be done thru website?
Admin login?
Admin login?
Nov 13, 2024Guru - Experienced User
NG may not have it up on there AU services. So you'll need to manually install the FW. RBS first, RBR lastly thru there web pages. I found this process works best: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2359585/highlight/true#M53030
Also if your in the EU region, do not attempt to load this version of FW.
Admin login?
