jsteele82
Aug 16, 2026Follower
RBE971 V12.1.10.12 - satellites do not broadcast the IoT SSID (regression from V9.13.x?)
System: RBE971 router plus 2x RBE970 satellites, both on wired backhaul, both showing Good. Firmware V12.1.10.12_5.3.16. IoT network enabled, 2.4 GHz only, WPA2-PSK. Main SSID is WPA2+WPA3. Probl...
3sp3r4nz4
Aug 18, 2026Aspirant
Hello,
Same problem here.
After extensive testing, IoT devices do not connect to the RBE970 (Satellite) when the RBE971 (Router) is in AP mode; instead, all IoT devices connect to the RBE971, even if the signal is poor and the RBE970 is closer with a better connection.
However, it works better when the RBE971 is in router mode; in that case, the majority of IoT devices connect to the RBE970...
Regards
