krwagnermitc
Sep 24, 2026Aspirant
RBE971 V12.1.11.15: Intel AX211 client severe latency on main 5 GHz SSID, fine on IoT SSID
Orbi 970 (RBE971) V12.1.11.15_5.4.12: Intel Wi-Fi 6E AX211 client gets severe latency on main 5 GHz network only Since roughly Sept 22–23, my Dell laptop (Intel Wi-Fi 6E AX211, Windows 11) gets 5...
donawalt
Sep 30, 2026Hero - Experienced User
If it helps krwagnermitc FURRYe38 I have an AX210 in a Dell laptop. I was having trouble with WiFi, I found there was an updated driver -it's pretty new, version 24.70.0.3 - driver date 7/29/2026. I installed that and it's been humming on 6 GHz ever since. Here's the link to it on the Intel web page if you don't have it - note it specifically says it installs 24.70.0.3 even though the driver file is 24.70.0
- krwagnermitcSep 30, 2026Aspirant
Thanks, that's a useful data point. I'm already on 24.70.0.3 (7/29/2026), so the driver isn't the issue in my case, but it's good to know the AX210 works well on 6 GHz with it. The 5 GHz issue on my RBR is independent of the client anyway; a Qualcomm laptop and a TV show the same thing.
