Volvo3389
Oct 12, 2026Follower
RBR350 Not Connected in the App
Hi I have a RBR350 mesh setup, I have an issue now saying the router ( Orbi router ) is not connected in the app. But the sateelites are OK can anyone help ?Orbi map
Oct 12, 2026Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
