SemiTruckOTTO
Sep 09, 2026Aspirant
RBR850 no admin access
I am having the same issues as many others. Both the Orbi App for iOS and desktop PC web browser cannot connect to the RBR850 for admin access. I have confirmed the default gateway ip via command pro...
SemiTruckOTTO
Sep 10, 2026Aspirant
I've tried Edge, Chrome and Safari web browsers.
I am not using an ISP provided modem, but a NetGear CM2000
Sep 10, 2026Guru - Experienced User
You may need to factory reset the RBR and setup from scratch with a ethernet connected PC.
Press the reset button in back of the RBR for 15 seconds then release. Give 1-2 minutes then access the RBR at 192.168.1.1 with a ethernet connected PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Also be sure to use a CAT6A STP cable between the RBR and CM modem.
