Zirene22
Jun 22, 2025Guide
Blocked/Not-Blocked Devices
Late last night I found a UI in the app that allowed me to "block" devices from accessing a specific satellite (showed a device list for the specific satellite with a blue background). This sounded l...
Zirene22
Jun 22, 2025Guide
That is understood. The issue is that the method by which this device was blocked (blocked from accessing a single satellite) is no longer available. The mobile app shows the device is not blocked in any way though it shows no wifi utilization (see image), and I can only set it to be blocked there. The Web GUI shows it is blocked with no option to unblock.
michaelkenward
Jun 23, 2025Guru - Experienced User
Can you see the Apple TV in the list of Attached devices on the router?
Zirene22 wrote:The Web GUI shows it is blocked with no option to unblock.
That is now something you have to control with the app.
