GusTTavo
Oct 18, 2026Star
Clients on Orbi Wi-Fi receive an IPv6 default gateway from an Orbi unit
I have a similar problem... My BGW320 is set to passthrough to my ORBI RBE770+2 satellites... Clients on Orbi Wi-Fi receive an IPv6 default gateway from an Orbi unit (fe80::ca10:2...
GusTTavo
Oct 20, 2026Star
Yes, I need to dig more into the Firewalla configurations, for sure.
When I use the BGW320 as the AP with passthrough to the Firewalla as the router, there are no connection issues. That's why I tend to think the Orbi in the AP mode is the culprit.
But then I am trying to use the wi-fi 7 from the Orbi plus the mesh range, since with only the BGW320 I get a lot of dead zones in the house.
Oct 20, 2026Guru - Experienced User
And you disable ALL wifi radios on the BGW?
Size of home in sq feet?
Distances between the RBR and the RBS?
What channels are you using on the RBR when in AP mode?
- GusTTavoOct 20, 2026Star
Thanks for your comments.
No, needed them to connect the wireless devices, just when testing without the Orbi.
With the Orbin connected, yes, all 3 wi-fi networks of the BGW are off.
3600 sqf, 2 stories.
one is about 40ft, with a few walls in between. Router is in the laundry area, inside a utility cabinet. The other satellite is on the 2nd story, almost above the router. about 20ft, give or take?
- Channel, set to Auto
- Channel width: 20/40 MHz on 2.4, 80/160 on 5, 160/320 on 6
- FURRYe38Oct 21, 2026Guru - Experienced User
Yes, be sure that when Orbi is online, disable ALL wifi radios on the BGW.
For this size of home, the RBR and just one RBS would be needed. Might try turning OFF one RBS.
The other satellite is on the 2nd story, almost above the router. about 20ft, give or take? <This is too close to the RBR. Try turning this one OFF or at least move it out farther to 30 feet or more.
Channel, set to Auto <Try manual channel 11 and 44
