ggb1979
Dec 15, 2025Aspirant
Confused by legacy network extenders still connecting
hi would appreciate some advice I am UK based, with vodafone fibre 500 connection. Recently purchased orbi 370 with 1 base unit and 2 satalites to replace the vodafone default router and voda...
CrimpOn
Dec 20, 2025Guru - Experienced User
The next step would seem to be figuring out which physical devices are on the network with IP 192.168.1.115 and 192168.1.119
The vast majority of devices on the network are probably obvious.
The "proof of the pudding", of course, is to power off the suspect device and see that the IP address disappears from the network. (It often takes several minutes for the system to update tables of connected devices. If those devices respond to ICMP ('ping'), they will stop immediately when they lose power.
