TOPS119
Aug 04, 2026Luminary
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
TOPS119
Aug 06, 2026Luminary
I did with the lot network and then the lot network disappeared....it's not even seeing the lot anymore.
Aug 06, 2026Guru - Experienced User
TOPS119 wrote:I did with the lot network and then the lot network disappeared....it's not even seeing the lot anymore.
Are you seeing the IoT network on any other devices? Does it re-appear if you reapply the original security setting?
Unfortunately, you seem to facing an unusual number of issues recently.
- TOPS119Aug 06, 2026Luminary
Yes the other devices see the lot network, and it reappear after placing it back. Actually I've faced faced 2 issues recently one in which the new firmware fixed and now this.
- FURRYe38Aug 06, 2026Guru - Experienced User
Checking this I have set WPA3 only set on my main WLAN and IoT enabled on 5Ghz with WPA2 only set. Android connected on IoT network and iPHone connected on main WLAN:
The tricky part about this is I have other android phones like my google pixel 10 which seem to connect fine with the 5ghz so its just the samsung thats lock to the 2.4ghz
I just notice this the backhaul actually shows the correct image of wifi 7 check on picture below but all the other connections only shows 2.4
- StephenBAug 07, 2026Guru - Experienced User
FWIW, there is a discussion thread about this on the samsung community forum:
The simplest test there is to put the phone into airplane mode (with wifi enabled), and see if that makes any difference.
- FURRYe38Aug 08, 2026Guru - Experienced User
IF you set up the IoT network for a 5Ghz SSID and set OPEN security temporarily, Does your one phone see the 5Ghz SSID name and can it connect to it?
Then set the IoT network for WPA2 and see if it will connect to it?TOPS119 wrote:
- TOPS119Aug 08, 2026Luminary
I carry the phone to another home that has a Google Wi-Fi and the phone connects to 5g with no issue. It wasn't a wifi 7 router but the phone wasn't stick on the 2.4 band
IF you set up the IoT network for a 5Ghz SSID and set OPEN security temporarily ON the 971, Does your one phone see the 5Ghz SSID name and can it connect to it?
