TOPS119
Aug 04, 2026Luminary
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
TOPS119
Aug 06, 2026Luminary
The tricky part about this is I have other android phones like my google pixel 10 which seem to connect fine with the 5ghz so its just the samsung thats lock to the 2.4ghz
Aug 07, 2026Guru - Experienced User
TOPS119 wrote:The tricky part about this is I have other android phones like my google pixel 10 which seem to connect fine with the 5ghz so its just the samsung thats lock to the 2.4ghz
FWIW, there is a discussion thread about this on the samsung community forum:
The simplest test there is to put the phone into airplane mode (with wifi enabled), and see if that makes any difference.
