TOPS119
Aug 04, 2026Luminary
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
schumaku
Aug 08, 2026Guru - Experienced User
StephenB wrote:Most islands are the same as US (FCC), Dutch and French islands are the same as Europe (ETSI). Either way, channel 44 is available in all countries, so geography is not a factor.
Nonsense, sorry. A single common 5 GHz channel isn't enough. On one hand, the backhaul on 5 and 6 GHz (is this DFS now?) requiring at least 160 MHz bandwidth, and then the front end, which does again require yet another 160 MHz bandwidth.
Sure location is a factor here: ETSI and FCC systems don't co-operate as we perfectly see on the OP case.
schumaku wrote:A single common 5 GHz channel isn't enough.
TOPS119 - did you have this problem before Netgear told you to reset the router 5 ghz wifi channel to channel 44? Does changing it to "Auto" make any difference?
- TOPS119Aug 08, 2026Luminary
They change to those channels because auto gave slow speeds even after the reset. So auto made no difference
- StephenBAug 08, 2026Guru - Experienced User
You might try 149, and see if the phone "sees" that.
These are the only channels available for me to choose from
