Epistrophy's avatar
Epistrophy
End of service replacement
Hi -- I received a notice that my current Orbi AC3000 system is no longer supported, so I'm looking to replace it with a newer Orbi 770.  However,  I have a number of  IoT devices connected to my cur...
  • FURRYe38's avatar
    Oct 04, 2026
    Yes you can use prior SSID name and password for your new system. I've been using same SSID on mine for 20 years. Zero issues.
    Also if your Orbi AC3000 series is working for you, you could keep it working if you wanted too. Can look into Voxels 3rd party FW for those models. Pretty good stuff and they update the important stuff.
    Good Luck.
