bhave's avatar
bhave
Re: I have spent weeks trying to get my pixel 8 pro to work on the orbi 970
I have been running the Orbi 973 with three satellites for about three weeks and I have encountered the same WiFi 7 issues. The phone will show excellent signal strength, but will pop up saying the wifi is connected but with no Internet access. If I disconnect and reconnect everything is fixed.
My phone is running the June security patch, as of this morning. I also found a thread which recommended turning off the "Adaptive Connectivity" in the phone's settings
Settings -> Network & Internet -> Adaptive Connectivity
So far this morning I haven't seen the "No Internet" issue, but will report back.
Here is a link to the thread describing issue..
https://xdaforums.com/t/anyone-got-problems-with-wifi7.4663627/
  • FURRYe38's avatar
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    What channel configurations are currently set on the router?
    • bhave's avatar
      bhave
      Hello,
      Sorry for the delay in replying, see the answers to your questions below.
      What Firmware version is currently loaded? V9.12.3.3_1.2.20
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Verizon G3100
      What is the size of your home? 5000sqft home / 2000 sqft carriage house
      What is the distance between the router 📡 and satellite(s)🛰️? The router is in the center of the home, 2 of the satellites are at each end of the home (more than 30 feet each). The third satellite is located in a detached building roughly 70 feet from the router. The satellites are all wireless backhaul.
      Does this happen with the RBS turned OFF? I haven't tested with the satellites all turned off, but I am working (wired) to one of the satellites in my home office and have never seen any issue with connectivity there. It definitely smells like a wireless connectivity problem. I have around 100 wireless devices throughout the home, and I have noticed connectivity problems with all of them (google homes, google TVs, WIFI faucet, sonos devices, etc...).
      What channel configurations are currently set on the router? The 2.4ghz is set to Auto and the 5ghz is set to channel 36. The WIFI on the Verizon G3100 is turned off.
      I am coming from an Orbi RBR40 with two satellites and an outdoor satellite. This system was entirely more stable for years than this new system. Given this new setup is over $3000, I would expect it to be, not only faster, but also substantially more reliable!
      If you need any additional information, please let me know! I would love to keep this system, but not in it's current operating form.
      Cheers.
      • FURRYe38's avatar
        Did Adaptive Connectivity change anything on the pixel phone?
  • FURRYe38's avatar
    Any progress on this?
  • This issue seems to be related to a bad MLO implementation on the Pixel 8 Phones. Many Pixel 8 users also using other Wifi 7 MLO routers report the same problem.
    Now with Android 15 the issue seems resolved. At least for me the connection from my Pixel 8 is now stable since some days. However the phone seems to not be using MLO. I have never seen it connecting to both 5 and 6 GHz bands since the update.
    • FURRYe38's avatar
      Thanks for feedback with this. Good to know that this is happening with other Mfr router and MLO systems.
