radterrax
Oct 05, 2026Follower
Lenovo Chromebook Plus 14 no longer connects to my Orbi RBE971
My Lenovo Chromebook Plus 14 no longer connects to my Orbi RBE971 as well. It just stopped. My Chromebook Plus 14 laptop works with all other routers except my Orbi. This is ridiculous.
schumaku
Oct 12, 2026Guru - Experienced User
radterrax wrote:My Lenovo Chromebook Plus 14 no longer connects to my Orbi RBE971 as well. It just stopped
Just ... out of the blue?
Was your Orbi RBE971 updated (likely automatically) around the same time?
Only a single RBE971 device (this model is the router), or operating along with one or some RBE970 satellites?
Using the primary wireless SSID (with what security settings like WPA2 or WPA3)?
FURRYe38 wrote:What Firmware version is currently loaded on the Orbi system?
A perfeclty valid question, should not be difficult to answer.
FURRYe38 wrote:Was the chromebook recently updated? If so, you'll need to check with Google on this?
Either way, around October 6th, Google has released updates for the Chrome browser and the ChromeOS operating system (just like every two to four weeks...).
So what Chrome OS version shows your Chrobebook "about" page?
