jtjtjtjtjt21
Oct 11, 2026Tutor
mDNS/Bonjour issue on RBE971 running firmware V12.1.11.15_5.4.12
Similar mDNS/Bonjour issue on RBE971 running firmware V12.1.11.15_5.4.12 I'm experiencing what appears to be a very similar issue on my Orbi RBE971, despite running the newer firmware V12.1.11.15_5....
schumaku
Oct 11, 2026Guru - Experienced User
jtjtjtjtjt21 wrote:Could a NETGEAR moderator
Keep in mind most moderators are volunteers.
Some had been involved in Orbi Beta testing, and have active/personal connections to Netgear QA and/or RD.
Strange that the IoT SSID dont show issues.
- jtjtjtjtjt21Oct 11, 2026Tutor
Thanks for the response.
One important clarification: Both Elgato lights remained connected to my main SSID throughout all testing. I only switched the Mac Studio between the main SSID and the 2.4 GHz IoT SSID.When the Mac was connected to the IoT SSID, both lights immediately appeared in Bonjour discovery and Control Center. Switching the Mac back to the main SSID (on either 5 GHz or 6 GHz) caused the discovery issue to return.
Even more interestingly, rebooting the Orbi router restored both lights on the main SSID, but within approximately 30 minutes, Control Center began intermittently losing individual lights again. Sometimes one disappears, sometimes both, and occasionally they return within seconds.
The lights remain reachable through direct HTTP requests even when Bonjour discovery fails.
This makes me suspect an intermittent issue with multicast/mDNS handling between wireless clients, potentially related to how the main and IoT networks handle discovery differently.
If anyone here has contacts within NETGEAR QA or firmware engineering, I’d really appreciate having these findings reviewed. I have packet captures available if helpful.
Thanks again!
