Gurjeee
Jul 07, 2026Guide
No internet on Guest Network Orbi 970
Hi, I recently purchased 2 pack Orbi 970, To be used as Network extender. basically after setting up the guest network, I tried to log in, but once logged in, i get a notification guest net...
- Jul 09, 2026
Hi, I thought I'd come on here to give you an update.
Everything is now working as it should, including the Guest Network.
The only problem I was having, was logging back in to RBR after full reset, I kept getting the password reset loop, but once I sorted the issue, I setup the WIFI networks again, put the RBR in AP mode, restarted my ISP router 1st, once fully booted up, I plugged the Ethernet cable into RBR 10G internet port, tested the guest network, and it is now working fine.
Thank you both for your help. it has been a steep learning curve, going from a TP link router to the Orbi 970. Everything is sorted, including the satellite.
Thank you again
Gurjeee
Jul 09, 2026Guide
Thank you again
Jul 09, 2026Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
