manusjuhl
Sep 28, 2026Guide
Orbi 772 backhaul through MoCa
Hi everyone, I hope someone can help point me in the right direction, because both I (and Copilot, Gemini, and ChatGPT) have run out of ideas. I recently purchased a new mesh system (Netgear Orb...
manusjuhl
Oct 07, 2026Guide
Is it possible for me to then use my current TP link to connect to the 2 rooms with MoCa and also as a WIFI-point. And then also to do what you suggest with 2 boosters insted of the Orbi?
Would you think it could cover my entire house 200 m2? (Otherwise it could "just" buy one more and connect though WIFI?)
Its my last day of returning the Orbi, so hope you can help me fast :-)
Oct 07, 2026Guru - Experienced User
So just asking, the following configuration doens't work with the MoCa adapters?
ISP modem>Orbi RBR<><ETH/Moca adapter connected behind RBR>ETH/Remote MoCa adapter<>Orbi RBS?
