electramet
Jun 25, 2025Tutor
Orbi 970 startup issues with 4 or 5 satellites
We purchased an Orbi 970 with 3 satellite and added 4 all connected through a netgear 10g ethernet switch. We noticed some issues on boot up where they may boot up as wireless, or stuck in config sy...
electramet
Dec 08, 2025Tutor
i have four satellites that work with the older first 13.1.14. The latest 13.2.1 does not seem to work with 4 satelittles
KevinLiT
Dec 17, 2025NETGEAR Moderator
Hello electramet ,
Thanks for that information!
This issue may occur if the officially supported satellites are out of sync with the firmware of your Orbi router. The satellites firmware will need to be updated to match the router to resolve the compatibility issues.
Navigate to the link below for the firmware download file for your RBE971:
https://www.netgear.com/support/product/rbe970
For step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Best,
Kevin
NETGEAR Team
