procreator
Jul 24, 2026Tutor
Orbi RBE360 and Epson ET-3958
After spending way too much time with Epson tech support, I was told that even though their printer was compatible with 5gHz or 2.4gHz, it does not play nice with mesh router systems. Their suggestio...
- Jul 30, 2026
Thanks for all the ideas.
I bought a cheap TP-Link WiFi Extender with an Ethernet port. The extender plugged into a wall outlet 4ft from the printer.
Works great!
Jul 28, 2026Guru - Experienced User
Thats got an older wifi 5 chip in it. Some had issues with AX much less BE. I can't remember if that version of orbi has an IoT option. If it does, set that up with wpa2 only mode. see what happens. You should have wpa2/wpa3 mixed mode running for wifi security.
