Leavemeb
Nov 24, 2025Guide
Strange Reddit IPv6 issue
Hi there, I've got a relatively new 770 on the latest firmware v10.5.20.7 things work mostly as they should but there is a consistent issue that I believe is a bug possibly. When I have IPv6 ...
PaulGo
Dec 05, 2025Luminary
I have Verizon FiOS and the Orbi 770. With my Galaxy S25, I do not now (and in the past) have any problems accessing Reddit with IPv6 on. With android, you need in LAN Setup to choose auto config, and additionally I have Enable RIPng turned on.
Dec 05, 2025Guru - Experienced User
This is on the RBR and this helps resolve the Reddit IPv6 issues?
Are you using ISP detected IPv6 DNS or custom IPv6 DNS?
PaulGo wrote:I have Verizon FiOS and the Orbi 770. With my Galaxy S25, I do not now (and in the past) have any problems accessing Reddit with IPv6 on. With android, you need in LAN Setup to choose auto config, and additionally I have Enable RIPng turned on.
