notCB
Aug 01, 2026Aspirant
Two devices can't ssh or ping
I have two devices, a Mac and a raspberry pi, that are connected to the same orbi satellite on the same main wifi ssid and same subnet using DHCP. The Mac is connected at 6Ghz and the pi is connected...
Aug 01, 2026Guru - Experienced User
Does this happen when all devices are connected at the RBR?
What Orbi system model do you have?
Firmware loaded on the system?
Be sure you have any Mac Address randomizers disabled on devices that have this feature:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
