kschac
Sep 04, 2025Aspirant
Resetting Orbi 770
I am trying to reset an Orbi 770 router and satellites in preparation for selling the system (I replaced it with an Orbi 870). I have read that I should press the reset button with a straightened pa...
- Sep 04, 2025
Thanks very much everyone. I was finally able to get all three units reset. I had to let the router stay on for a couple of minutes before starting the reset procedure.
Sep 04, 2025Guru - Experienced User
Press for only 15 seconds.
- kschacSep 04, 2025Aspirant
Will try this.
I was able to reset the two satellites -- their lights turned amber and began flashing, but not the router. Strange.
- FURRYe38Sep 04, 2025Guru - Experienced User
After releasing the reset button power LED should go from AMBER to GREEN, Then you can power them OFF after GREEN is seen.
