zattack8203
Nov 15, 2025Aspirant
Router/Satellite 770 issue - MLO Backhaul?
Current setup: Router is in the main area of the house with the modem and coax line (xfinity). The Satellite goes through 1 wall and up one floor of a house to my room. From the satellite, 1 ethernet...
zattack8203
Nov 16, 2025Aspirant
I have a custom Desktop computer.
- Courgar airface rgb mid-tower case
- msi mag z790 tomahawk max wifi ddr5 atx motherboard
- 32 gb ram - corsair vengeance rgb - ddr5 6000mhz
- deepcool ls520 liquid cpu cooler
- C: - storage stick is 1 GB ............. D: - storage stick is 2 GB
- NVDA RTX 4060TI (8gb)
- be quiet! power 12 850W 80+ Gold Fuly-modular atx 3.0 power supply
- Windows 11
Based on that, I have swap ethernet ports with the computer and Satellite and yields that same result. While there is no status indicators on the satellite to figure out how much speed going through the ethernet, but checking on the motherboard, the speed is working at 2.5 gbps on a Cat 5e cord.
I haven't swapped the ethernet cord, I guess that is something I can try ...
Nov 17, 2025Guru - Experienced User
zattack8203 wrote:I have a custom Desktop computer.
Do you have any other device you can connect through the satellite?
When the problem starts, can you ping the satellite from a device connected to another mesh element?
- zattack8203Nov 17, 2025Aspirant
The other device that is connected to the satellite is my cell phone. Every time when I notice the internet problem for the computer, my phone works completely fine.
- StephenBNov 18, 2025Guru - Experienced User
Are you checking this with mobile data turned off on the phone?
