PaulGo
Aug 03, 2025Luminary
Samsung Galaxy S25 and Wi-Fi 7
I have the Orbi 773. The Galaxy S25 work great with Wi-Fi 7 and where the reception is marginal, Wi-Fi 7 has a substantially stronger connection speed than Wi-Fi 6e. However, this seems to be a Samsung problem that the battery usage on Wi-Fi 7 is substantially greater than Wi-Fi 6e. If you have this problem, do a Google search on how to disable Wi-Fi 7 on the Samsung phone. You will also find many comments about this. Hopefully Samsung will come up with a fix.
- TOPS119Apprentice
The issue I face is my Galaxy s25 is stuck on 2.4ghz network only did we find a fix for this ?
- PaulGoLuminary
The Orbi app and the web GUI can display that wrong information. It has happened to me, but with the latest firmware it corrects after several days. As a test, try enabling IoT and setting it to 5GHz only and connect your Galaxy S25 to the IoT SSID.
