1Robert's avatar
1Robert
satellite turning off the wifi when connected to Ethernet
Having a similar issues on my 871 with the satellite turning off the wifi when connected to Ethernet.
I have them in AP mode, current firmware, reset thousands of times, set the units up within 10 feet of each other after reset to link. App on computer is working, shows connected by Ethernet on one satellite and the other showing connected by wifi. It shut off the wifi to the Ethernet connected satellite and the other one has the wifi working and taking up the slack of the lost wifi signal. Wifi speed at the Ethernet satellite drops to half will not connect to phone or any other wifi connection. But it is keeping the Ethernet connected devices working.  App shows
  • FURRYe38's avatar
    Does the one Ethernet RBS work correctly if not ethernet connected and just wirelessly connected to the RBR?
    How is the RBR configured for AP mode? Dynamic or Static?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How is the one RBS ethernet connected to the RBR? Directly behind the RBR or is there a LAN switch in between?
    What CAT# LAN cable are you using? CAT6A STP is recommended.
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
  • StephenB's avatar
    Please start your own discussion thread, as this one was resolved over a year ago.
