conroyw
Dec 05, 2025Apprentice
Satellites aren't picking up any devices
I just purchased another RBE770 to connect to my existing mesh network to work a perceived coverage issue. I have a 3 story home with approximately 2400 square feet per floor. The new device is inc...
Dec 05, 2025Guru - Experienced User
What does the RBRs web page show in a web browser?
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
15 feet is TOO close in between the RBS. 30 feet or more.
What mobile device are you using? Android or Apple?
What version of the Orbi app are you using?
No bots in the system here. Find support in the forums or here: https://www.netgear.com/support/
