lachlanwm
Sep 06, 2026Aspirant
Satellites wont connect iPhone & Sonos to wifi after 12 hours
I have an Orbi RBE771 router with three RBE770 satellites connected via Ethernet CAT6 back-haul through two unmanaged Netgear switches. The router and one satellite are in the house, the other two...
- Sep 13, 2026
Yeah I thought about doing that too, and will try connecting the Satellite in the shed directly to the router, but still daisy chained to the second Satellite. This will need a minor change to the cable run in the cupboard in the house.
lachlanwm
Sep 08, 2026Aspirant
Hi Kevin, my RBE770/771 hardware is v1. The new firmware you recommended is for v2 hardware, and looks to be why it failed. I checked
https://www.netgear.com/support/product/rbe770 and
https://www.netgear.com/support/product/rbe771 both firmware versions are what mine have installed.
Is there likely to be an updated firmware for REB770/771 v1?
Sep 08, 2026Guru - Experienced User
We are hoping for v1 FW soon. I'll post soon as it's been officially released.
