lachlanwm
Sep 06, 2026Aspirant
Satellites wont connect iPhone & Sonos to wifi after 12 hours
I have an Orbi RBE771 router with three RBE770 satellites connected via Ethernet CAT6 back-haul through two unmanaged Netgear switches. The router and one satellite are in the house, the other two...
- Sep 13, 2026
Yeah I thought about doing that too, and will try connecting the Satellite in the shed directly to the router, but still daisy chained to the second Satellite. This will need a minor change to the cable run in the cupboard in the house.
lachlanwm
Sep 12, 2026Aspirant
Thanks everyone for your help. I have re-worked my network given the suggestions below.
Wifi drops (was stable for months, but recently became unstable. Hub is Dell 6000 which is my workstation)
Router
Switch
│ Sat
Switch
Sat Hub Sat
Wifi drops + Hub connected but no internet (experiment where switch should be downstream from Sat - didn't work. Also took 2 of the satellites offline for experimenting)
Router
Switch
Sat
Switch
Hub
Stable (has been for 24 hrs now :) by daisy chaining the satellites, and no downstream switch. All iPhones, iPads, Sonos and Ring devices enjoying stable wifi connectivity)
Router
Switch
Switch Sat Sat
Hub Sat
Thank goodness I laid 2 ethernet cables down to the shed!
Still looking forward to the new firmware.
Sep 13, 2026Guru - Experienced User
lachlanwm wrote:Stable (has been for 24 hrs now :) by daisy chaining the satellites, and no downstream switch. All iPhones, iPads, Sonos and Ring devices enjoying stable wifi connectivity)
Although it might not be practical (depending on where the cable runs are), you'd get the best performance if you connect the satellites directly to the router LAN ports, and then connect the switches to router or satellite LAN ports.
- lachlanwmSep 13, 2026Aspirant
- lachlanwmSep 15, 2026Aspirant
I have re-worked the ethernet cales, and as the Router only has 4 ports:
- Internet from FTTP
- To 16 port switch
- To Satellite 1 in the shed's workshop, daisy chained to Satellite 2 in shed's office
- To 5 port switch in shed's worksop, to hub in office
everything is stable.
Thanks all
- FURRYe38Sep 15, 2026Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
