Hunter66
Jan 23, 2026Aspirant
Scan to email
Hello, I installed the Orbi 371E and when I try to set up the scan to email on the HP Color Laser Jet MFP M277dw, I cannot get it to work. Any help would be great!
Jan 23, 2026Guru - Experienced User
What makes you think its a router issue and not a printer issue?
Hunter66
The scan to email worked with the older Orbi wireless mesh I had. Then I installed TP Link Deco mesh system which I found out was an issue with that system. I recently upgraded to the Orbi 371e but i cannot get it to scan to email. Maybe the printer/scanner is no longer supported?
- FURRYe38Jan 23, 2026Guru - Experienced User
Check to see if Armor or SPC is enabled. if so, try disabling these.
If the scan to email failed on another router system, you'll need to get with HP and find out what is happening with that feature on that printer.
