Dave1Wetzel
Aug 28, 2025Aspirant
Separate network access
How do I configure my RBE770 so I can use one of the ethernet ports to run a line to a rental unit I have in the backyard - and so that renters using that will have internet access but not be able to...
CrimpOn
Aug 28, 2025Guru - Experienced User
The RBRE770 is designed to have one primary network (both WiFi and 'wired') which is in one IP subnet. No method to segregate devices.
What ISP is the 770 connected to? If it is also a 'router', then the 770 can be connected to one port and the rental unit to another port.
