Dave1Wetzel
Aug 28, 2025Aspirant
Separate network access
How do I configure my RBE770 so I can use one of the ethernet ports to run a line to a rental unit I have in the backyard - and so that renters using that will have internet access but not be able to...
CrimpOn
Aug 29, 2025Guru - Experienced User
Thanks for the diagram. Both Firewalla and pfSense sell appliances for under $500 which can be placed between the RBE771 and the TP-Link to prevent the rental unit from accessing the RBE771 networks.
https://www.netgate.com/appliances
This has the advantage of avoiding Double NAT for the Orbi network. It does, however, definitely create a Double (or maybe Triple) NAT for the rental unit. OK for 95% of users, but a definite limitation for those specific applications. If the rental unit requires complete network access, the only solution is to have the ISP install separate service to the rental unit.
