Leavemeb
Nov 24, 2025Guide
Strange Reddit IPv6 issue
Hi there, I've got a relatively new 770 on the latest firmware v10.5.20.7 things work mostly as they should but there is a consistent issue that I believe is a bug possibly. When I have IPv6 ...
Leavemeb
Nov 24, 2025Guide
Might be a similar issue to this thread: "Issues with various apps on android devices" it sounds like a similar problem
- FURRYe38Nov 24, 2025Guru - Experienced User
Ok, seems to be resolved by disabling IPv6. We have been passing along to NG IPv6 issues as we get them in. NG has disabled IPv6 by default on newer versions of FW while they work on getting IPv6 fully working. So for now, you'll need to disable IPv6 for now. Will keep checking with NG about this.
- nck4857Dec 05, 2025Aspirant
I've had this problem with my Samsung phones since we bought this system (770) last year. Just had to disable IPv6 entirely.
- FURRYe38Dec 05, 2025Guru - Experienced User
I highly recommend submitting a support ticket to NG to help let them know whats going on.
Good Luck.
