newkid1885
May 05, 2025Aspirant
Support horrible, can someone help me have orbi 970 and they won’t fix it
I have been calling the last 10 days straight and no one has helped me
newkid1885
For the last 10 days I have non working orbi 970 network I have premium support. The team is unable to resolve it. We’ve been going back for back-and-forth Just need them to replace it. Basically, the power cycle is happening every 2 to 3 hours reboot it gets, power LED yellow or amber on back and it just stuck I have to go physically disconnect the power and re connect it to reboot it and then it works for a while same thing again and again and again almost 10 to 12 times throughout the day it’s getting problematic. I don’t know what to do and I’m just stuck and I hope someone can resolve this. There’s an actual case number if you need it, you can message me in privately.
May 05, 2025Guru - Experienced User
Is this happening with the RBR or the RBS?
Have you swapped power adapters with the RBS or RBR to see if the power LED continues this?
Tried different wall outlet?
How long have you had the system for?
- newkid1885May 05, 2025AspirantIt happens to rbr
Yes swapped the power adapter already
Yes moved the unit to different power
