gfrassmann
Jul 16, 2025Aspirant
Support issues with very expensive Orbi Products
I own a Netgear RBE971 and three satellite RBE970s I have for almost 3 days been going back and forth WITH SUPPORT OVER AN ISSUE WITH THE MAIN ROUTER, WHICH IS THE 970 LAN PORT FAILURE! their initia...
gfrassmann
I need to correct something I was using voice to text. The main router is the 971 that is the one with the land port failures the three 970s are fine because these are Netgear black which can only come from Netgear and I purchased them directly from Netgear. I had hoped that this would actually be a reasonable support experience.
