olaf615
Oct 13, 2026Follower
The 770 Series Sucks
I bought the 770 Series Tri-Band Wifi 7 Mesh 3-pack, and I consistently have trouble with my wifi. I often lose the signal (several times daily), and it makes it difficult to enjoy any streaming serv...
Oct 13, 2026Guru - Experienced User
What WiFi devices are connected to the system?
Does Ethernet have same issue?
Do you have a v1 or v2 770 series? v2 will be seen on the bottom sticker if present.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 44 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
