OrbiTechDude
Jun 05, 2025Apprentice
The community has waited six months for a firmware update
NETGEAR, the community has waited six months for a firmware update, yet critical issues persist—especially regarding wireless backhaul performance, Apple device compatibility, and overall network sta...
OrbiTechDude
Jun 12, 2025Apprentice
Here’s a photo of the new:
The white with the very light grey makes it hard to capture the details. If that isn’t clear enough for you to decipher, I can type out the specs.
Jun 12, 2025Guru - Experienced User
Looks like 3.42Amps and 64watts on new power brick vs 3.16Amps and 60watts
I'll check mine today and take some speed tests as well.
- FURRYe38Jun 12, 2025Guru - Experienced User
Speed tested with iphone and adroid pad behind both RBS today. Seeing to spec speeds on both. just over 700Mpbs on the iphone and over 900Mpbs on the android pad.
Uptime on the system has been 4 plus days now with RBS both wirelessly connected.
Heres my power brick my system is using:
