Billy1956
Aug 23, 2026Aspirant
The installer said the Gateway would work with my Orbi 973
Two weeks ago, I switched from Cox to AT&T Fiber. The installer said the Gateway would work with my Orbi 973 as plug-and-play with no settings changed. It took a while to connect, but eventually it w...
Billy1956
I went with option #2, and so far, everything’s working well. I set IP passthrough on DHCP to the router’s MAC address and turned off the gateway’s radios. Could the Double NAT have been the reason for the connection issues after the factory reset? Will the same problem happen again if I need to power cycle the router, satellites, and mode? After making the setting changes on the Modem.
- StephenBAug 24, 2026Guru - Experienced User
Unlikely, generally double-NAT only gets in the way when you are doing port forwarding (and you would have been using double-NAT all along).
Not clear what went wrong, but turning off the gateway radios would have also helped if the gateway is adjacent to the router.
- FURRYe38Aug 24, 2026Guru - Experienced User
You should be in a better place now with the system. Once you got the wifi disabled on the ISP router and using DMZ for the RBR, should run better and be more stable. Power cycling the system should bring it back to a good working condition now since you made the changes.
