Majmoz's avatar
Majmoz
Unable to get VPN setup on Orbi Router RBE771
I have been trying to setup the VPN on the router per the instructions given. Now I getting the following from the OpenVPN config log: TCP/UDP: Incoming packet rejected from [AF_INET]..., expected peer address: [AF_INET]..... (allow this incoming source address/port by removing --remote or adding --float)
The script resets after 60 seconds. Don't know how to correct this.
  • Sorry. I was confused. Was not aware that Netgear offers a VPN service. Bitdefender Armor includes a VPN feature.  I have never enabled Armor.  ("Free Trial" triggered a thought, "and then it costs money".)
    Most questions on the Community Forum about VPN are typically about:
    OpenVPN hosted by the Orbi router.  The feature found on the Orbi web interface, Advanced Tab, Advanced Settings.  This feature allows customers to access their local network from the internet using OpenVPN Client software loaded on a computer or mobile device.  Instructions and configuration files are downloaded from the Orbi router.  This feature does not support connecting to the router from within the LAN.
    OpenVPN Client.  Rather than install VPN software on each of their devices, some users would rather that their WiFi router act as a VPN Client which bundles connections from every device into a VPN tunnel to a VPN provider on the internet. (NordVPN, ExpressVPN, etc. etc.)  There are several brands of WiFi router which provide this feature, but Netgear routers do not.
    Running VPN client software on customer devices.  This is when users have signed up with a VPN host service (NordVPN, ExpressVPN, etc.) or have been directed to use a VPN to access their corporate or organization network.  The Orbi WiFi router has nothing to do with this activity.
  • CrimpOn's avatar
    CrimpOn
    I seem to recall reading about some of the T-Link routers having this capability.  An internet search might turn up more definite information.
    https://mashable.com/uk/roundup/best-vpn-routers-uk
    By-the-way, another solution is to install a VPN Client device on the local network, such as:
    https://www.gl-inet.com/products/gl-mt2500/
    If the router itself is a VPN Client, then it will bundle every device on the home network into the VPN tunnel (light bulbs, printers, cameras, thermostats, garage door openers..... everything.)
    With an appliance, you get to decide which specific devices benefit from VPN.
  • Hello, I do have a need to make my WiFi router act as a VPN Client, and you mentioned that several brands provide this feature, would you mind to tell me what brands do? thanks!
  • CrimpOn's avatar
    CrimpOn
    Which version of OpenVPN is installed on the test devices?
    What are the test devices?
    How is VPN being tested? (drop WiFi and switch to cellular?  drop WiFi and connect to a WiFi Hot Spot on a cell phone?  Use a neighbor or commercial WiFi connection?)
    • Majmoz's avatar
      Majmoz
      It is OpenVPN 2.6.14 on a Windows 10 Lenovo laptop. It doesn't even startup. This is the line that it faults on:
      "2025-04-06 16:00:14 TCP/UDP: Incoming packet rejected from [AF_INET]192.168.1.1:xxxxx[2], expected peer address: [AF_INET]69.244.22.61:xxxxx (allow this incoming source address/port by removing --remote or adding --float)"
      • CrimpOn's avatar
        CrimpOn
