ron111157
Aug 13, 2026Apprentice
Upgrading a RBR50 to RBE771
Is there an easier way to update the info into the new router without typing in all the reserved IPs and other common setting? I really don't want to add 60+ items one by one again.
ron111157
Aug 14, 2026Apprentice
Thanks! I didn't think so but never hurts to ask.
- FURRYe38Aug 27, 2026Guru - Experienced User
Once you get the system all setup, be sure to then save off a backup configuration to file. Saves time if a factory reset is needed.
