demoleon63
Dec 19, 2025Aspirant
UPnP Issues after Upgrade
Just upgraded from an Orbi RBR850 to the 970 and everything is going fine except for UPnP. Prior everything just worked. When I started a server the control points could see it and there were no is...
CrimpOn
Dec 19, 2025Guru - Experienced User
demoleon63 wrote:Just upgraded from an Orbi RBR850 to the 970 and everything is
Please clarify: the entire system was upgraded? (router and two satellites) and was configured with exactly the same WiFi credentials (SSID/password) as the previous system?
- demoleon63Dec 19, 2025Aspirant
Yes, exactly.
