demoleon63
Dec 19, 2025Aspirant
UPnP Issues after Upgrade
Just upgraded from an Orbi RBR850 to the 970 and everything is going fine except for UPnP. Prior everything just worked. When I started a server the control points could see it and there were no is...
CrimpOn
Dec 19, 2025Guru - Experienced User
Thanks. Sometimes I get hung up on terminology, i.e.
demoleon63 wrote:Just the router.
The goal is to have a Synology NAS on the local network accessible from applications installed on the Mac, which is on the same local network?
Access from the internet is not desired at this time?
- demoleon63Dec 19, 2025Aspirant
NO, everything is working as before. I can access the Synology and the Synology can access the Mac and I can see all my devices on the network and the internet is working. But UPnP isn't. If I set up a server (I've tried both my Mac and NAS) the endpoints don't see it. And vice versa. It all worked fine with the old router. I would set up UPnP server and the endpoints could immediately see it a browse it a play from it. But now nothing.
