demoleon63
Dec 19, 2025Aspirant
UPnP Issues after Upgrade
Just upgraded from an Orbi RBR850 to the 970 and everything is going fine except for UPnP. Prior everything just worked. When I started a server the control points could see it and there were no is...
CrimpOn
Dec 19, 2025Guru - Experienced User
Thanks. Sometimes I get hung up on terminology, i.e.
demoleon63 wrote:Just the router.
The goal is to have a Synology NAS on the local network accessible from applications installed on the Mac, which is on the same local network?
Access from the internet is not desired at this time?
demoleon63
NO, everything is working as before. I can access the Synology and the Synology can access the Mac and I can see all my devices on the network and the internet is working. But UPnP isn't. If I set up a server (I've tried both my Mac and NAS) the endpoints don't see it. And vice versa. It all worked fine with the old router. I would set up UPnP server and the endpoints could immediately see it a browse it a play from it. But now nothing.
