demoleon63
Dec 19, 2025Aspirant
UPnP Issues after Upgrade
Just upgraded from an Orbi RBR850 to the 970 and everything is going fine except for UPnP. Prior everything just worked. When I started a server the control points could see it and there were no is...
Dec 19, 2025Guru - Experienced User
demoleon63 wrote:I've tried Minimserver and Asset UPnP. No luck. Tried various control point apps all report no server on the network.
Have you tested this with the UPnP setting in the router both enabled and disabled?
- demoleon63Dec 19, 2025Aspirant
It is currently enabled. I will try it disabled.
