TJS1234
Apr 18, 2026Aspirant
What is the downgrade process from 12.1.8.7 to 9.13.2.1?
TOPS119
Apr 18, 2026Luminary
I use the same process as updating to downgrade from the web portal
Apr 19, 2026Guru - Experienced User
Which FW version are you currently using? The Downdrage FW or the last official v9 release FW version?
TOPS119 wrote:I use the same process as updating to downgrade from the web portal
