Dazza762's avatar
Dazza762
Luminary
Oct 22, 2025
Where has the sort function gone?
I've recently updated my network from an Oribi 750 to a 870. When using the web UI to view the settings for the 750, on the list of connected devices I could sort the view by clicking on any of the headers for the list (see screenshot for example).
On the 870 web UI, there seems to be no sort as function on the same page. I found this sort as view option really useful with the 750 system. Is there any way of getting back on the 870 web UI?
      • FURRYe38's avatar
        I'll check my 770 series. Seems that the 970 series has this feature.
  • FURRYe38's avatar
    So checking my 770 series using MS Edge on Windows 11 24H2, All titles secions are working accept for MAC Address:
    Selecting once on each section is sorting the column selected.
    • StephenB's avatar
      FYI, none of them are clickable on the 870.  It'd be great if this worked.
    • Dazza762's avatar
      Dazza762
      Luminary
      None of the are clickable on my 870. Seems like a bad backstop as it worked fine on the web UI of my previous 750 setup. I found it a very useful feature.
  • AvaTaylor23 wrote:
    Sorting by column was removed in the Orbi 870 web UI — there’s no way to re-enable it. Only workaround: use the Orbi app or wait for a future firmware update that restores sorting.
    If that was the case I would have thought NG would have advised FURRYe38​ of that when he reported it to them and they asked for the debug logs to identify why it wasn't working.
