TOPS119
Apr 28, 2026Luminary
WIFI 8
You all see wifi 8 is now a thing and other companies promoting it. I thought the orbi 970 was future proofing ? with this new wifi 8 it seems like we are soon to be getting new hardware again for wi...
krgoodwin
May 04, 2026Guide
Agree especially being in the minority with a Google Pixel 10 Pro. Why would I want to consider WiFi 8 when WiFi 7 is still having issues and I suspect has yet to implement all the promises. It is all a rolling baseline. But if you believe in marketing hype - press. Since I don't live on the Internet, I would be happy with a stable 2G system or as Jimmy Buffett would say, " I don't want a 12 lb. Nestle's crunch for 25 dollars, I want my Junior Mints!"
schumaku
May 06, 2026Guru - Experienced User
krgoodwin wrote:Agree especially being in the minority with a Google Pixel 10 Pro. Why would I want to consider WiFi 8 when WiFi 7 is still having issues and I suspect has yet to implement all the promises.
All Google Pixel 8/9/10 [XL, Pro or not] share the very similar Wi-Fi tech. On Wi-Fi 7 maxing out on 160 MHz bandwidth, with a max PHY rate of 2401 Mbps on 802.11ax (resp. 1733 Mbps on 802.11ac). This is done to keep the energy consumption low. Many product reviewers or tech geeks don't appreciate Google is not running ahead, and does remain very conservative.
There is still a lot of wild nonsense written in the Internet since these phones are out, like users claiming lack of MLO.
In fact, like virtually all Wi-Fi 7 clients, it can do NSTR Mode (Nonsimultaneous Transmit and Receive Operation) only. NSTR Mode refers to non-simultaneous transceiver mode or synchronous mode. That is, simultaneous receiving and sending operations are not allowed. At the a time, all links can only receive or all links can send data on one a single band only.
In my observations, the Pixel 10 Pro and the Pixel 8 Pro are now (as Wi-Fi 7 client) - changing channels without involving roaming - as well as the Pixel 6 (a Wi-Fi 6 client, all enrolled to the Android Beta program), currently operating Android 17 QPR1 Beta1, are all operating amazingly reliable on our Netgear WBE7xx APs, as of writing on V12.8.0.7, since availability (about one week). Earlier Android 17 Betas required the [Fix connectivity] (Settings ->WiFi or Internet, top right icon) every now and then to regain Wi-Fi access.
STR Mode (Simultaneous Transmit and Receive Operation) on the other hand, refers to simultaneous transceiver mode or asynchronous mode. That is, two or more links work completely independently, and they don’t interfere with each other. This is a mode wireless infrastructure like Mesh systems can use on the wireless backhaul. Netgear Insight indicated this mode earlier as "active" MLO.
