grservidio
May 29, 2025Aspirant
Wired Network Connections
I recently upgraded from my Orbi RBS50 Mesh LAN to an Orbi RBE970 Mesh LAN. On the old RBS50 router, I used to see all the wired connections when viewing the connected devices. With the RBE, I don'...
May 29, 2025Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
grservidio
May 31, 2025Aspirant
I am already using option #3, using the Orbi is AP mode.
- FURRYe38May 31, 2025Guru - Experienced User
Well if you have wifi devices connect, then those may show as wireless devices with is expected.
For ethernet connected devices, if they are connected behind the RBR, then those will appear as wired.
