Mark1281
Jul 03, 2019Aspirant
2.4ghz slower speed on RAX80 AX8
MY ISP is 150MB down and on my previous Linksys router I could obtain that speed with no problem on the 2.4ghz band. ON my RAX 80 I can only get to 85MB on 2.4ghz, but no problem getting t...
schumaku
Jul 03, 2019Guru - Experienced User
Potentially an interoperability issue between your 2.4 GHz client (802.11g, or 802.11n even if it's 802.11ac on 5 GHz) and the 802.11ax 2.4. GHz implementation. Ensure you run the current drivers on your wireless clients - check with the WiFi makers drive download sites as the computer vendors like Asus, Dell, HP; ... are ways behind with updating ("qualifying") drivers.
- Mark1281Jul 03, 2019AspirantThanks, but I’ve done all that and no difference. Most of the clients are new and on prior router there was no issues.
- schumakuJul 03, 2019Guru - Experienced User
Mark1281 wrote:
Most of the clients are new and on prior router there was no issues.Again: The RAX80 does (like any WiFi 6 device) run the 2.4 GHz and 5 GHz radio interfaces in an 802.1ax mode with a compatibility mode for older standard clients. So there can be interoperability issues - that's the risk of using the "latest" technology here. Your previous router was a WiFi6 (802.11ax) one on both 2.4 GHz and 5 GHz? Look, many Inhell 802.11n/802.1ac failed or badly struggled connecting reliably and on some standard performance against WiFi 6 access points before Intel has released driver updates.
"done all that" is rather useless - list the exact details of the WiFi interfaces in your devices and the driver versions for future reference.
