AX8
35 TopicsCAX80 test speeds
hello everyone i'm still waiting on netgear to get back to on support i emailed them because the phone support tells me don't worry anything else your online. i get different issues all the time I've done 4 factory resets ,one time it kept telling me i was connected remotely and all my info was the same but no Internet. right now i can only connect to my modem thru my computer, nighthawk app quit and put me in remote access again all my devices are gone again. testing speed im wireless right now becuase my wife is sleeping on the couch on my 5g xfinity speed 561.0 speedtest 762.66 my 5g guest network is xfinity 236 speedtest 292 there is nothing on my guest networks but me testing 2.4 xfinity 82.5 speedtest 59.79 average over multible tests 2.4 guest xfi 65.8 speedtest 59.7 i know 2.4 is slower but this much difference when the app did work 2.4 was 431. on speedtest the other thing is streaming amazon i get a german message first then japanese then UK and finnally english saying it timed out. didnt happen with xfinity modem/routerNighthawk RAX80 very unstable - losing connections
Hi all, I've bought the RAX80 six weeks ago and it's been very unstable since then: - devices losing wifi connections - devices not seeing the wifi network - RAX80 losing internet connection (orange led) I did resets to factory settings several times (with rebooting modem, RAX80 and all the connected devices). I only use default settings now - with Smart Connect enabled. No extra wifi6 settings like MU-MIMO. But nothing works. After a few days all the problems above come back again. I'm very disappointed in this 300 euro router. In times like this with working at home en schools closed losing wifi and internet connections is very frustrating. Is there something I can do about this problem - except for returning the RAX80? ThanksRAX70 Smart Home, DoS attacks, WiFi speed issues
I've had a ton of issues with this router which is actually the RAX70 tri-band model. The one they said would resolve early issues with the RAX80. There are constant issues keeping smart home devices connected to the router. These include: LIFX bulbs (both older and newer models), Dyson Fans, Roomba vacuum, Litter Robot, Petkit feeder, Wemo smart plugs, Withings scale, HP Tango printer, etc. The smart home devices show up in the Nighthawk App but show a link rate of N/A. With the recent update to the app, it now shows these devices as offline. I've tried going with factory settings, adjusting recommended settings like OFDMA, 20/40 coexistence, WMM & QOS for airtime fairness, channels 1, 6, & 11 as well as lowering speed from 600mbps on 2.4 network, disabling smart connect. I've tried what seems everything in the book to get this router to work, and nothing works longer than an hour to keep the devices connected. I also experience the DoS Attacks constantly throughout the day. Yes, I know the false flags on port 443 from Amazon, Facebook, Apple, etc. These are present but there are also attacks from unknown locations in Germany, Hanoi, Canada, Netherlands, & more using ports like 59, 80, 179, 1338, 2222, 8000, 10009. My WiFi speeds on WiFi 6 devices like iPhone 12 Pro's download speed will plummet to 12mbps. Pretty bad considering I have gigabit Verizon Fios. And sometimes it will kick our iPads off wifi. Armor has been enabled & disabled with no effect on the issues. Factory Resets work for about 10 minutes. I ensured to not use any channels on the 5ghz bands that conflict with nearby airports. The router is out in the open and can be seen from most of the condo except the bedrooms. I'm seriously at a loss of how to fix the issue. Anyone seen this before or know how to resolve it? It's a bummer to think I might have an almost $300 paperweight bought a couple months ago. This is my first time using netgear and it's not enticing me to want to stay in the future if this is how it is with zero support options past 30 days. Slow speeds across devices, and all the constant DoS attacks below. These are all from the last hour.RAX75 individual bandwidth usage in the device list
It's all just shows 0.00 Mbps for all upload/download Internet usage for every single device. QoS has been enabled and it’s showing flat out 0 for every device. The router also has the latest firmware (Firmware Version V1.0.3.102_1.0.48), no further updates available at the moment.RAX80 very inconsistent discovery of local devices
Recently I have discovered my local devices are having trouble seeing each other, the only change I can think of is I assigned a few more static IPs and had a firmware update. Has anyone else experienced this or have any ideas what could cause this? I have tried several things like assigning all static addresses (oddly duplicate Nest devices can't both have static according to the UI) or turning off certain QoS like WMM (when disabled no wireless devices could connect) and etc. (Have not tried turning off AX because that was a huge point in getting a wifi 6 router) Some examples are: -Google Home Devices show unavailable or disconnected -Castable devices are missing several devices even when I can "connect" to them in Google Home app -Can't connect to my Harmony Hub from my Android -Nest Hubs will occasionally disconnect (according to the display) and then reconnect, one is within 5 feet of the router Thanks for the help!Solved2.6KViews0likes3CommentsNighthawk RAX80 Continually Drops Internet Signal
My Nighthawk WiFi Router continually drops any kind of internet signal (both Ethernet and WiFi) periodically. At least a few times a day. Not sure what the heck is going on. I’ve updated firmware. Factory reset. Turned it on and off again. I’ve just kind of run out of ideas to try to fix this. My cable modem is the Surfboard DOCSIS 3.0 Cable Modem (Model #SB6190). This is starting to get really frustrating. And my gf made the comment the other day that the internet worked better when we had the modem given to us by Comcast/Xfinity.... talk about a punch to the gut especially after how much I talked this combo up. Anyone have the same issue or know of a fix that I am missing?my AX8 RAX80 slow on WiFi
My new AX8 Nighthwak RAX 80 can not make more than 150Mbs on WiFi. The speed coming to the router is 920 Mbs download and 950 Upload. The firmware was updated befote the instalation. The range simce to be fine but the speed 4 times less than expected. Please, help. If I can't fix next coupe days I consider return.RAX80 vs R9000 vs Whatever
Hi! I recently upgraded my internet to Gigabit and my R7000 just isn't up to the job. I've been looking at the RAX80 (AX6000) and the R9000 (X10). They are the same price. I'm struggling to make a decision. It seems like the AX80 is newer and might be more future proof, but the X10 seems to have more features. I chatted with Netgear support and they just sent me to the "Compare these products link", not info otherwise. Quite a few people suggested the R78000, but if I'm going tp spend $200, I'd rather spend a little more and get something that isn't three years old. Is the AX8 the spirital successor to the X10? Here are the things that are important to me: - Wired speeds. I'd like to get as close to Gigabit speeds as possible - Future proofing. If I'm going to spend $400 on a router I want it to still be relevant in a couple of years - Features. The X10's Plex server and fiber connection sound interesting, but not sure I'll ever use them. - Range Extender. I have a fairly large house and would like an accompanying range extender (I have an EX7000 now). - As silly as it sounds, the AX80 looks betterRAX80 recalls previous settings after factory reset
I have been trying to reconfigure my RAX80 router however each time I make a configuration change that requires a reboot, the router boots back to its previous configuration. I went to the Backup menu and clicked on the Erase button however this does not seem to work either. I then learnt about the 30:30:30 reset rule which I performed and happily it rebooted into a seemingly new instance. However once again as soon as i made a change requiring a reboot, it reverts back to the previous settings. It brings back old passwords, wifi settings the lot. I have been at this for almost 3 days now and at the point of despair. If anyone knows how to get round this that would be superb.RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if you hit refresh. Tried to call tech support to tell them problems with the firmware but I get level 1 telling me if I tried resetting the router. 1. If I set QOS to Highest it some how resets for the device and even changes the label i've assigned to it. 2. Problems with my smart devices because the iptables must not update correctly for wired devices. 3. Labels assigned with edit button on administration/attached devices wont save for some reason. Bought this new router cause all the advertising says it can handle more smart devices, seems to crash all the time. I'm ready to to send it back.
